Offsetting all surfaces to represent paint
3
I have a model of a door. I would like to offset all surfaces by 0.5mm to represent painting the door, this would create a new solid model which I could put into an assembly and then I could define components from the painted door.
How would I do this? Is it a good idea?
Thanks in advance, Chris.
RE: Offsetting all surfaces to represent paint
If it works for you and your company ... it's a good idea.
One method could be to create a zero-offset surface from the faces to be painted, and then thicken that surface to represent the paint. Make sure the Merge option is not selected.
I like CBLs suggestion.
A few years ago I sent a suggestion to SW to add a feature to add paint or any other type of material to a surface. It would help with tolerances and FEA, for example.
Chris
SolidWorks 09 SP4.1
ctopher's home
SolidWorks Legion
3
Copy the body of the item to be painted.  Use "Delete Face" to delete a single face from the copied body without patching.  You will then have a near-complete surface body for offsetting.
What to do about the missing face?  Copy it (zero offset) before deleting, then knit the offset to the original surface body.
Excellent tip, Tick.
Yes, that tip worked very well Tick!
