Dry piston ring material
What would be your favored material for piston rings in a compressor (dry) going to 10,000 psi or more? Gas is hydrogen.
RE: Dry piston ring material
This will be a multi stage compressor.
In the low pressure stages you can use traditional materials.
In the high pressure stages ceramic materials work.
