Continuous UV Detection
I am looking for a manufacturer of an application/system that can provide continuous UV detection to identify if our pellets are off-spec or there is a more serious problem in our process.
We would like to do this before visible colour change occurs. Right now we can do this in a batch process where we pass clear pellets under a UV light to see if they fluoresce. Has anyone seen this type of application in use and/or can anyone recommend a vendor who manufactures this type of equipment for continuous detection? Thanks.
RE: Continuous UV Detection
A proper process with good control and consumption rates of the various components relative to each other with some spot checks should be good enough.
Pat
See FAQ731-376: Eng-Tips.com Forum Policies for tips on use of eng-tips by professional engineers &
http://eng-tips.com/market.cfm
for site rules
We want to pass some of the pellets from a side stream under a UV light continuously and if they fluoresce this would indicate a problem. I have seen this done in industry before, but I don't recall the name of a manufacturer who makes this type of equipment.
Pat
for site rules
