heating oil
heating oil
Is there any other common ways of heating engine or hydraulic oil than by an immersion heater (either inline or in tank)?
RE: heating oil
RE: heating oil
RE: heating oil
Perhaps a little more information would help with suggestions. How much heat do you need? What is the flow going into the tank?
RE: heating oil
RE: heating oil
RE: heating oil
RE: heating oil
RE: heating oil
deltaT = Q/(M*cp)
Where:
deltaT = temperature increase (°C)
Q = heat =5kW = 4300 kcal/h = 71.7 kcal/min
M = mass flow rate = 2 gpm * 0.0038 m^3/(gpm min)* 880 kg/m^3=6.688 kg/min
cp = specific heat = 0.48 kcal/(kg °C)
deltaT = 22.33 °C = 72.2 °F
RE: heating oil
your wrong because one degree C = 1.8 degree F. that means if you have a deltaT of 22.33C then you have a deltaT of 40.194F.
But a temperature of 22.33C is the same as a temperature of 72.2F. But this is totally different than a deltaT because F and C are not on an absolute scale.
RE: heating oil
RE: heating oil
Unless you can come up with another heat source, an electric immersion heater in the tank is your simplest option, especially if it is only for start-up.
