NX6 ASSEMBLY COMPONENTS COMBINE INTO ONE SOLID PART
Hi NX6 Users,
How can you combine multiple components in assembly work part into one solid part in NX6? I'm currently used IDEAS and we use a command called "construct" and add to entire assembly with or w/o history and we're done. I couldn't figure out in NX6. Please help...Thanks!
Maxxforce23
Maxxforce23
RE: NX6 ASSEMBLY COMPONENTS COMBINE INTO ONE SOLID PART
create new part inside the assembly, copy solid bodies using wave links, and the unite copied bodies.
Best regards
Simon NX4.0.4.2 MP10 - TCEng 9.1.3.6.c - (NX6.0.3.6 MP2 native)
www.jcb.com
Life shouldn't be measured by the number of breaths you take, but by the number of times when it's taken away...
Best Regards
Hudson
www.jamb.com.au
Nil Desperandum illegitimi non carborundum
I use NX6.
Groeten, Michel
www.kvi.nl A leading Dutch institute in atomic and subatomic physics
