Abaqus BC just in one direction
Hi all,
I would like to apply a special boundary condition to a surface in Abaqus:
In the positive U1-direction displacement should be possible. In the negative U1-direction displacement should not be possible.
This behavior is similar to an interaction between two instances but in my model there is just one instance.
Do you know if this is possible in Abaqus (it is possible e.g. in ANSYS)?
Please tell me, if you do not know what I mean.
Thanks a lot!
Johannes
Thanks a lot!
Johannes
RE: Abaqus BC just in one direction
A possible approach is to define contact between the surface and a fixed rigid analytical surface.
tanks a lot, this is exactly what I mean. This is the way I've already solved my problem but I wondered if there is a possibility doing it 'easier' with constraints e.g.?
