1.5 MVA blowing rectifier diodes
1.5 MVA generator is blowing diodes on the rotating rectifier and tripping off because of a ground fault. Only about 30% load. Any ideas. Sorry don't have more info.
RE: 1.5 MVA blowing rectifier diodes
Ground fault where ? Generator rotor winding ? RR assembly ? Single ground fault or double ?
Sorry, need more info.
Muthu
www.edison.co.in
After you find and repair the ground fault, the unit may stop blowing diodes.
Bill
"Why not the best?"
Jimmy Carter
