Upsetting Graphics Issue
I almost can not take it anymore. This graphics issue is driving me nuts. When I single LMB on an item in my assembly I get the standard options box that pops up, no problem. However, if I try to zoom or rotate only the area that the pop up box covers rotates or zooms until I press QTRL-Q. I have already uninstalled the video card driver and made sure it is the newest supported versin as well.
See attached pic.
Dell T3400
Vista x64
SW2009 SP4.1
nVidia Quadro FX4800
8GB ram
See attached pic.
Dell T3400
Vista x64
SW2009 SP4.1
8GB ram
RE: Upsetting Graphics Issue
Is this what you have?
It could be:
-Ethernet issues
-Server issues
-Sometimes working with dual monitors
-Too many apps open/running/both
Also, more info here: thread559-228247: Graphics Card
Chris
SolidWorks 09 SP4.1
ctopher's home
SolidWorks Legion
Things change quick in technology--not sure if the Quadro is really the problem in your case, but I've seen lots of people with similar issues. Try the driver Chris mentioned above.
Jeff Mowry
www.industrialdesignhaus.com
A people governed by fear cannot value freedom.
Also go to Control Panel > Ease of Access Center > Make Keyboard Easier to Use, and check the box for Underline keyboard shortcuts.
I can't offer a guarantee that either of those settings will cure your problem, but they have been known to correct graphics glitches in Vista systems.
Dan
www.eltronresearch.com
Dan's Blog
Turn ON Windows Aero as CBL suggests.
I had the symptoms you describe on a couple of my Vista systems.
Turning Windows Aero back on fixed it for me.
Cheers,
Anna Wood
Anna Built Workstation, Core i7 EE965, FirePro V8700, 12 gigs of RAM, OCZ Vertex 120 Gig SSD
SW2010 SP0, Windows 7
http://www.solidmuse.com
http://www.phxswug.com
Cheers,
Anna Wood
BB
BB
Scott Baugh, CSWP![[pc2] pc2](https://www.tipmaster.com/images/pc2.gif)
FAQ731-376: Eng-Tips.com Forum Policieswww.scottjbaugh.com
Who recommends to turn off the Aero option?
I have the same graphics glitches if Aero is OFF on both my Vista and Windows 7 machines.
The suggestion to turn ON the Aero graphics came from Jim Wilkenson or Ron Bates of SolidWorks when I was having issues with my Windows Vista computer last year.
Cheers,
Anna Wood
S-034389
S-027404
There are 3 issues that show turning off is a workaround to some issues. one is for 2008, but it still shows there are bugs having on just the same as having off.
Darned if you do, darned if you don't.
Cheers,
Anna Wood
So far this has worked for me. Had to reboot to get the settings to take.
A star for you.
Standing
SolidWorks Pro 2009 x64, SP3.0, PDMWorks Workgroup, SolidWorks BOM,
HP xw8600, 64-bit Windows Vista Business, Service Pack 1
Intel Xeon CPU, 3.00 GHz, 16 GB RAM, Virtual memory 166682 MB, nVidia Quadro FX 4600
