Small program, very strange bug
Hi, I have got this incredibly strange bug happening with some code I've written and I fear there could be something fundamentaly wrong with (either me or) my system.
Here's the code (it's short, I promise):
#include <stdio.h>
#define FILE_NAME "sdtest.dat"
int main()
  FILE *fp;
  long idx = 0;
  fp = fopen(FILE_NAME, "r");
  if (fp)
    fread(&idx, sizeof(long), 1, fp);
    printf("old: %d\n",idx);
    idx++;
    fclose(fp);
  fp = fopen(FILE_NAME, "w");
    printf("new: %d\n",idx);
    fwrite(&idx, sizeof(long), 1, fp);
  fclose(fp);
  return 0;
The first time I run it I get the following output:
old: 0
new: 1
which increments for each subsequent run, eg.
old: 1
new: 2
then
old: 2
new: 3
etc
BUT, once I have run it enough times for it to get to
old: 25
new: 26
the next run produces
old: 0
new: 1  !!!
The program can not read the file contents when it contains 26! It reads in the file contents of x"1A 00 00 00" as x"00 00 00 00"  (verified with debugging).
I have tried this same code on a Unix system at work and there were no problems, what on earth could be causing this?  Any insight/advice would be very much appreiated, thanks.
Setup
CPU:       AMD Athlon 1GHz
OS:        Win 98SE
Compiler:  VC++ 6.0
RE: Small program, very strange bug
PS. I know there's some unnecessary braces after the second fopen so you don't have to mention that.
The text character 27 represents an escape character and as such will not read and write properly to a file in text mode. Change the read write status of the file to "rb" and "wb" then it will properly increment up to 255, once you reach there, you will need to read/write multiple bytes. The reason you did not have the problem with UNIX is it uses binary as the standard IO mode while windows uses text as the standard IO mode. It is always helpful to specify mode to make portability easier.
