Damping pressure gauge fluctuations
We will be monitoring room pressure with a very low pressure (+/- 0.1 w.c.) differential transducer. There is air circulating in the room because of fans. I would welcome suggestions as to how to eliminate pressure fluctuations seen by the transducer.
RE: Damping pressure gauge fluctuations
I honestly don't know if the scintered filter or the long capillary had the greater effect.
There also the approach of averaging at whatever is taking the pressure readings.
