high voltage generator
Hi all,
we are realizing a project on helicopter that needs high Dc voltage for operation. The trick is that the generation must be compromised with low weight and volume.
One solution could be to install a 270V generator and a converter to achieve the desired -60/+600 Volts DC.
Do you know manufacturers that could be contacted to get practicable/alternative solutions?
RE: high voltage generator
Keith Cress
Maybe I'm on the wrong forum. I'll check the aviation forums.
But, not all supplies are suitable for all loads and operating conditions. For example. No matter how dependable and efficient an engine driven supply may be, it may not be suitable as an engine starting aid.
WHAT IS YOUR APPLICATION?
Bill
"Why not the best?"
Jimmy Carter
don't overlook very small engineering firms
with a total of 10 employees, including manufacturing.
I once worked for such a Company,
building very small electric motors
for the Main Battle Tank.
With a problem like yours, that would be my first choice.
I know a story from another person in communications technology. A tiny company had a patent which a very very large company was trying to buy from them. No deal.
That was a long time ago. Siemens.
