Wheel friction
Wheel friction
Wheel friction
I'm calculating bearing loads for a turntable with wheels running on circular rails. The wheels are positioned vertically and they are not driven.
Does anyone know how to calculate axial bearing load?
RE: Wheel friction
I made a simplified sketch of the wheel/rail/turntable arrangement. There  are other forces in the wheel/rail interface, but I left them out for simplicity.
In real life the turntable is a circular steel structure with 60 wheels evenly spaced on two concentric rails.
Hope it helps explaining my problem.
RE: Wheel friction
hi ipas
Well that helps for starters well rolling friction coefficients for the wheel and track can be obtained from that site link I gave you earlier.
The axial force at the bearing are you looking for the centrifugal force due to the rotation of the turntable?
If so go to this link and scroll down till you come to
rotary motion.
http://www.roymech.co.uk/Useful_Tables/Form/Dynamics.html
desertfox
RE: Wheel friction
The axial load will be:
W * mu * sin(a)
mu is the coefficient of adhesion between wheel and rail (this is not the coefficient of friction).
a is the slip angle of the wheel.
a will be small, so axial load will be small.
RE: Wheel friction
just a WAG, but if you're talking point contact, wouldn't the axial load be null as long as the axis or axes are located radially from the center of the table?
The problem comes in when using wheels that make contact on their width such as rubber or polyurethane. These will deform and "squirm" when forced along the track.
It still might be of minor concern, but if this is something you must quantify, it may require experimentation....perhaps the axes being canted.
If you're looking for power requirements to turn the table under load, there are a lot more variables to consider; the main one being rolling resistance of the wheels.
RE: Wheel friction
..or what MintJulep said; I was slow on the typing
RE: Wheel friction
Thank you guys!
MintJulep: Where can I find out more about these things? Can you please advise me a book or other recource. Thanks again!
RE: Wheel friction
There will also be a slight slipping owing to the width of the bearing ,i.e. the inner and outer surfaces in contact with the rail have a slight mismatch in velocity.The associated forces  should be minimal.
The major axial force, F, is the centripetal force on the bearing of mass m
F=mw^2
w= angular velocity of the turntable
RE: Wheel friction
Correction
F=m*w^2*r
r radius of turntable
RE: Wheel friction
ipas,
Any statics and dynamics text book covers the fundamentals of this.
RE: Wheel friction
If roller/ball bearings were used, wouldn't it eliminate the slipping?
RE: Wheel friction
Will the turntable's rotational centering be provided by the rollers? A steel or urethane cylinder rolling on a flat surface will try (insist!) to travel in a straight line. To get it to "turn" or follow a curved path will require some axial load, and as others pointed out, the inner and outer edges to slip since they must travel slightly different distances but must rotate at the same rpm.  Tapered roller bearings have their races and rollers designed as cones to reduce the sliding and create more perfect rolling.
http://www.ntn.ca/pics/roller_guidance_pic1.jpg
http://www.bearings.machinedesign.com/guiEdits/Content/BDE_6_4/images/fig17.jpg
It may be possible to "steer" each roller bearing to reduce the axial load, but some cylindrical roller and track wear will still occur due to slipping.  It Maybe easier to provide centering with a bearing in the center of the table, and mount the rollers on casters, to avoid having to machine the roller axle seats with great precision, or go thru an elaborate alignment adjustment.
Unless there is resilience somewhere between track and turntable (flexible turntable relative to loads, etc) I don't picture many of the 60 rollers carrying their share of the load
