An equivalent for honeywell Q624A1014
Hi!!!!
I`m searching for an equivalent of this solid stage spark generator from honeywell (model Q624A1014) but I need it cheaper. I do not know so much about this items, can anyone give me a right direction about it.
Thanks!!!
Roland
RE: An equivalent for honeywell Q624A1014
As far as a "equivalent" the Q624 offers a special feature which prevents ignition spark from being picked up by a Honeywell UV flame scanner, and you might have a hard time matching that feature.
If you prefer Honeywell you should check with them, I know they also offer a Q652B1006 solid state spark generator for comm/ind gas burner applications.
You also might try checking with other ignition transformer suppliers like Allanson.
