Whichever is Greater
Hello! I'm trying to set up a several equations, with variables that may or may not be defined (if not defined = 0), then hopefully have Mathcad chose the greatest result.
Example:
Given: D=5, F=10, T=*undefined*(assume "0")
Find U:
U1 = 1.4(D+F)
U2 = 1.2(D+F+T)
U = U1 or U2, whichever is greater
Any idea, how I go about this? Just a point in the right direction is all I need. I just got back into Mathcad.
RE: Whichever is Greater
I think a combination of both would work, I have actually 4 equations to compare (not 2), so the 'max(x)' function should suffice...  Thanks for your help!
