How to generate internal detents
Hello, I am trying to make some small bumps on the inside diameter of a tube to create a detent feature for a part that slides within. I sketched an ellipse on a plane tangent to the ID, then tried to use Dome and a circular pattern around the tube centerline to duplicate four or more of the bumps, but I keep getting 'The face selected for the dome feature is no longer in the model. Please use the Edit Definition to re-select the face.' Any ideas on how to create these?? Thanks!
RE: How to generate internal detents
