Acrylic Laser cutting: odor reduction
Has anyone run into this problem? If you have how did you fix it? We cut acrylic sheets with lasers (X-Y axis) and exhaust the fumes out of the plant at roof high vents. We are trying to reduce this problem as it does have a distinct odor. We have looked at stack extensions and activate carbon filter systems. I want to see if there other solutions we should look at?
RE: Acrylic Laser cutting: odor reduction
Thanks for the responses chicopee.
