Foundation Undermining
I recently had an inside waterproofing system installed. I am now getting conflicting stories on whether it was installed properly. The debate is over whether weep holes, which were drilled completely through the solid bottom block of the basement wall, will allow sediment to come in and eventually undermine my house footings. I have a very high water table and the soil is primarily made up of clay. Can you tell me if this will be a problem?
RE: Foundation Undermining
Clays are essentially resistant to the passage of groundwater through them because they have a fine microstructure which does not readily allow water to pass through it (that is why canal beds are made of puddled clay because it doesn't leak water). Why have you drilled hole in your waterproofing?
Andy
Andy Machon
Andy Machon
