how can I edit a default drafting template? - NX6
I am using NX6 and would like to remove the 'SIEMENS' logo from the drafting template title block and replace it with my own. On opening NX6 I choose the default model. On entering the drafting mode I choose the 'A3 with views' template - it is this template I would like to modify and be able to fully edit...
many thanks,
John
many thanks,
John
RE: how can I edit a default drafting template? - NX6
you can not do that. If you open the template file (I know where they are) in modeling you see nothing thus if you then go into drafting you can't edit all of the title block. If you start a new drawing and import the template file you can edit the title block but I still can not edit the 'SIEMENS' logo.
Can someone tell me the correct way to be able to fully edit and save any changes to the file for example:
'/templates/A3-views-sheet-template'
many thanks,
John
got it!
many thanks,
John
Best Regards
Hudson
www.jamb.com.au
Nil Desperandum illegitimi non carborundum
thanks for the info, I followed a similar method...
cheers,
John
