axial shortening data in defining the tabular data
Could someone please tell me if there is a way to use "stress versus axial shortening" curves from experimental data to define the work hardening part of the stress - plastic strain curve in MARC. The manual says the data has to be from tensional experiments to define them in a tabular form. Is there a way to define stress versus shortening strain in tabular form.
SS
RE: axial shortening data in defining the tabular data
If you know the length over which the axial shortning occurred then you'll have stress v's strain that you can use in a tabular form.
I'd suggest you post this question in the general FEA section as it isn't specific to MARC, but materials testing.
