A.S.M.E code case 2235-9
i have been hearing alot of rumors lately that 2235-9 UT in lieu of RT will be added to the 2010 addenda,is this true?
RE: A.S.M.E code case 2235-9
h
Summary of Key Actions and Pending Items from the ASME Code Committee Meetings October 2006 through April 2007
J. Robert Sims April 18, 2007:
http://74
http://www.ndt.net/article/v12n09/cziraki.pdf
h
I wonder if ASME V will be suitably updated?
Keep in mind this, once this code case is adopted in Section I, whichever volumetric examination method is selected will need to be used throughout fabrication. This means if a fabricator uses RT and repairs are required during fabrication, UT cannot be used. IF UT is selected, it must be used until fabrication is completed.
