SELECT USING REFERENCE SETS
In NX6 is it possible to select assembled components which are assigned to a particular reference set? I'd like to use this to set them to a particular layer or blank them.
James
RE: SELECT USING REFERENCE SETS
You have multiple components in an assembly assigned to a reference set and you want to pick them all based on the ref set?
There is no selection filter that is based on reference set, perhaps a group would serve your needs?
There is no filtering for reference sets. However, you can sort the ANT by refernce set name and use it to select the components you want to blank. Not sure if you select them for a layer move.
Ben Loosli
