Monorail Weak Axis Bending
This might sound like a silly question, but the reference manual i'm reading confused me.
When considering side thrust and weak axis bending on a monorail I understand that you consider only one flange to contribute to weak axis bending strength.
However, in this design example i am reading, the beam is unsupported along its entire length and it appears when they check combined bending (i.e. Mfx/Mrx + Mfy/Mry =< 1.0) they assume the compression flange is braced. Shouldn't the flange be considered unbraced (i.e calculated Mu and determine the reduced value of Mry?
RE: Monorail Weak Axis Bending
"you consider only THE flange"
A monorail beam should be designed as laterally unsupported between supports unless there are other intermendiate lateral braces present.
Recognize that the hanging load from the bottom of the beam is a "righting" load that will have a tendency to pull the beam back vertical unlike a load on the top flange which will have a tendency to push the beam over.
