End conditions - help!
I'm a relatively new InRoads user. I am working on a levee template and I need to have the top of levee (which is a point at the CL crown) have 2 end conditions - one for the right side and one for the left. I can't figure out how to do this - I only know how to apply 2 end conditions to a segment, but the top of my levee is not flat. When I apply an end condition for each side, the template only draws one side when I run it through. Please help!
RE: End conditions - help!
Also, make sure that when you attach your end condition to the template that you use the reflect option.
In The Roadway Designer, make sure the existing dtm is the target prior to creating the model.
HTH,
Champ
