fastener stack update
I'm still testing fastener assembly -
Does the screw length update of a fastener assembly when the hole length is changing? Must I manualy rework the fastener assembly stack?
thx in ad
RE: fastener stack update
At the moment, you have to do this manually, but it's a fairly easy task as you simply select the fastener, press MB3, select the 'Edit Reusable Component...' option, edit the length parameter and hit OK.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
