UI Styler or Block Styler Tree View
Hi! Is there any way to make a tree view using NX Open or do I need to make a separate GUI for this? Thank you...
Raymond
RE: UI Styler or Block Styler Tree View
NX 7.5 will add a tree view block to blockstyler, in earlier versions you need to use an external gui for example winforms. There is a .NET example for NX called "FeatureBrowser" that uses winforms and NXopen to populate a treeview with information about open parts.
//Petter
