Abaqus 6.9-1 & Fortran & IMSL = HELP!!!
Hi
I have problem with running simulations into Abaqus using IMSL Fortran library. When I'm compiling fortran source I have such kind of information:
Abaqus JOB ch5_1_081209
Abaqus 6.9-1
Begin Compiling Double Precision Abaqus/Explicit User Subroutines
12/10/09 18:44:24
End Compiling Double Precision Abaqus/Explicit User Subroutines
12/10/09 18:44:25
Begin Linking Double Precision Abaqus/Explicit User Subroutines
12/10/09 18:44:25
libifcoremt.lib(for_vm.obj) : error LNK2005: _for_deallocate already defined in LIBIFCOREMD.LIB(libifcoremd.dll)
libifcoremt.lib(for_vm.obj) : error LNK2005: _for_allocate already defined in LIBIFCOREMD.LIB(libifcoremd.dll)
libifcoremt.lib(for_f90str.obj) : error LNK2005: _for_cpystr already defined in LIBIFCOREMD.LIB(libifcoremd.dll)
libifcoremt.lib(for_f90str.obj) : error LNK2005: _for_concat already defined in LIBIFCOREMD.LIB(libifcoremd.dll)
libifcoremt.lib(for_open.obj) : error LNK2005: _for_open already defined in LIBIFCOREMD.LIB(libifcoremd.dll)
libifcoremt.lib(for_close.obj) : error LNK2005: _for_close already defined in LIBIFCOREMD.LIB(libifcoremd.dll)
libifcoremt.lib(for_wseq.obj) : error LNK2005: _for_write_seq already defined in LIBIFCOREMD.LIB(libifcoremd.dll)
libifcoremt.lib(for_wseq.obj) : error LNK2005: _for_write_seq_xmit already defined in LIBIFCOREMD.LIB(libifcoremd.dll)
   Creating library explicitU-D.lib and object explicitU-D.exp
imsls_err.lib(flexlm.obj) : error LNK2019: unresolved external symbol __iob referenced in function _imslf_flexlm
libifcoremt.lib(for_diags_intel.obj) : error LNK2001: unresolved external symbol __iob
libifcoremt.lib(for_nt_open_proc.obj) : error LNK2001: unresolved external symbol __iob
libmmt.lib(libm_error.obj) : error LNK2001: unresolved external symbol __iob
imsls_err.lib(flexlm.obj) : error LNK2019: unresolved external symbol _lc_get_config referenced in function _imslf_flexlm
imsls_err.lib(flexlm.obj) : error LNK2019: unresolved external symbol _lc_set_attr referenced in function _imslf_flexlm
imsls_err.lib(flexlm.obj) : error LNK2019: unresolved external symbol _lc_hostname referenced in function _imslf_flexlm
imsls_err.lib(flexlm.obj) : error LNK2019: unresolved external symbol _lc_status referenced in function _imslf_flexlm
imsls_err.lib(flexlm.obj) : error LNK2019: unresolved external symbol _lc_username referenced in function _imslf_flexlm
imsls_err.lib(flexlm.obj) : error LNK2019: unresolved external symbol _lc_userlist referenced in function _imslf_flexlm
imsls_err.lib(flexlm.obj) : error LNK2019: unresolved external symbol _lc_checkout referenced in function _imslf_flexlm
imsls_err.lib(flexlm.obj) : error LNK2019: unresolved external symbol _lc_perror referenced in function _imslf_flexlm
imsls_err.lib(flexlm.obj) : error LNK2019: unresolved external symbol _lc_lic_where referenced in function _imslf_flexlm
imsls_err.lib(flexlm.obj) : error LNK2019: unresolved external symbol _lc_new_job referenced in function _imslf_flexlm
imsls_err.lib(flexlm.obj) : error LNK2019: unresolved external symbol _lc_get_errno referenced in function _imslf_flexlm
imsls_err.lib(flexlm.obj) : error LNK2019: unresolved external symbol _lc_free_job referenced in function _cleanup_lm_license
imsls_err.lib(flexlm.obj) : error LNK2019: unresolved external symbol _lc_timer referenced in function _imslf_highland_check
libifcoremt.lib(for_init.obj) : error LNK2019: unresolved external symbol ___argv referenced in function _for_rtl_init_.
libifcoremt.lib(for_init.obj) : error LNK2019: unresolved external symbol ___argc referenced in function _for_rtl_init_.
explicitU-D.dll : fatal error LNK1120: 16 unresolved externals
Abaqus Error: Problem during linking - Double Precision Abaqus/Explicit User Subroutines.
  This error may be due to a mismatch in the Abaqus user subroutine arguments.
  These arguments sometimes change from release to release, so user subroutines
  used with a previous release of Abaqus may need to be adjusted.
Abaqus/Analysis exited with errors
I'm using:
Abaqus: 6.9-1
Intel Fortran Compiler 10.0.35
IMSL* Fortran Numerical Library 6.0
Do you now what is wrong or did you ever adding IMSL into fortran into Abaqus
Thanks for any help
perzo
