How to create a MACRO in UG
I need to design one Macro who create layers, in ascending order, and create the name according to an alphanumeric pattern controlled and incremental (f.e. spline_01, spline_02, etc). In each one of these layers we need  insert a spline (diferent XYZ points in a txt file).
If when  you go to create a layer you detect that in this layer contains some objects, or if it is already named, the Macro should jump to the next one.
The ideal, it will be to create the Macro like a loop and parameterized.
RE: How to create a MACRO in UG
Which version of UG/NX are you using?
A GRIP program will do that job and be easier to control and modify.
Ben Loosli
The UG verison is the nx4
I can't help but ask why you need to do this in the first place?  After all, with only 256 layers, you could soon be out of places to put Splines.  Perhaps it might be better to just give them unique names and Hide them and then use some Macro/Program to Show the needed Spline.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
