45 degree latrolets...some questions
I have searched and come up with nothing on latrolets concerning weld sizes. I am trying to prove to a colleague that using a 1" sch 160 latrolet on a 20" sch 40 pipe is not the way to go. (Because thats the way they always did it)
Calculating branch wall thickness required per B31.1 we could get away with using a schedule 5S. Why the heck would we use a schedule 160!
Also i am having no luck finding end weld sizes for latrolets in general. Any insight into this? My concern comes from the attached picture for both these points.
(picture is of a sch 160 latrolet)
RE: 45 degree latrolets...some questions
ht
It's much stronger configuration than that seen on the photo.
I hope I gave you an idea.
Regard
Giuliano
Ive looked at that chart closely. From what i can tell there is no way to deduce weld size from the given dimensions.
Giuliano81
Unfortunately we currently need a 45 degree entrance in to the run pipe. I am looking into changing that also..
Thanks for the responses..
Good Luck!
Hench
Trying this again....
Have a look at the attached. These are pages 34 and 35 out of the Bonney Forge catalog.
Good Luck!
Hench
If there is something i am missing here please point it out. Did you see the picture of the latrolet i posted? There is nothing in these catalogs that looks this way.
Until these came in i had no idea the amount of weld these would take to attach to the pipe.
I think if you look at the welded photos, they are expecting you to fill up the entire bevel. I have never ordered the 45's and I usually stick with the sch 40 weldolets, most often I use threadolets. However I do feel the same as you do that the beveled throat is way to deep and there is an excessive amount of weld required to weld them out to flush. However that is just an opinion, I have no idea what level of stress is factored into the joints.
I am eager to hear what other real users are doing.
StoneCold
Use the appropriate fitting and wall thicknesses as designated by your pipe spec. Heavy wall thicknesses are often specified for small bore piping for mechanical strength reasons rather than pressure capacity. Presuming Sch160 is specified for your 1" piping, the appropriate fitting would appear to be a 20"x1" Sch40 x Sch160; this is not the same as just a Sch 160, it will be lighter.
