Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...I have learned more through this forum than I did on a two day course. Thanks to everyone for their help and other postings that I have found useful..."
Geography
Estimate of Drained Young's Modulus E' of Clay
qhtony (Civil/Environmental)
10 Dec 09 6:42
Hi Guys,
Got a problem that has annoyed me for a while. I understand drained Young's Modulus E' of clay can be obtained from Oedometer consolidation test in the Lab; and there are also many published correlations between CPT qc, relative density and E' for SAND. However, I was wondering if there way to estimate E' of CLAY from CPT, SPT or other methods rather than laboratory testing? This is because we don't always have Oedometer or 1D consolidation test data for every single project...
fattdad (Geotechnical)
10 Dec 09 9:37
You don't typically derive soil modulus from the odometer.  You derive soil modulus from the triaxial test or in the field, I like the dilatometer.
f-d
¡papá gordo ain't no madre flaca!
Delijosi (Geotechnical)
15 Dec 09 4:58
Here is the equation for deriving E' for clay from SPT N;
E' = 1 / (450 N) m2/KN
   = 1000 / 450N m2/MN.
Note that SPT N is uncorrected.
This is equation is after Stroud and Butler, 1975.
Mccoy (Geotechnical)
15 Dec 09 16:37
There are a few published correlations for constrained modulus and qc for clays as well...
What I use:
Sanglerat 1972 is pretty much used in Europe for silty clays
Mayne et al. 1990 for the ECPT
johnnix (Geotechnical)
19 Dec 09 11:53
Check here http://www.cpt-robertson.com/pub.html and download the latest 2009 paper. You may also find useful the CPT guide available from http://www.geologismiki.gr/Guides/Guides.html
Kindest regards
paganel (Geotechnical)
29 Jan 10 9:44
No matter how, CPT or SPT can only give a semi emperical correlation of the stiffness of the soil. As the clay's behaviour is very complex during CPT or SPT penetration in clayey soil,it can not be easily ascribed as compression or shear or something else.
If you want to get more reliable results, oedometer test is neccesary.
dgillette (Geotechnical)
29 Jan 10 15:00
How does one get Young's mod from an oedometer?  Don't you have to ASSUME Poisson's ratio because of the lateral constraint (uniaxial strain vs uniaxial stress)?
30 Jan 10 1:54
To qhtony:E' means constrained modulus or not? I thought it is. If not ,you could only rely on triaxial tests CD test.
30 Jan 10 8:18
To paganel: for the use in my model, it is a constrained modulus. you're right. triaxial CD with specified cell pressure will give me the E' I want.
Close Box
Join Eng-Tips® Today!
Join Us             Close
