Laser cutter transmissive window
I am cutting a fabric material using a laser cutter. It can be difficult to cut this particular material because wrinkles easily and does lie flat.
I would like to use some kind of glass plate to hold down the work piece. Is there a glass material that is NIR transmissive enough to not be cut by the laser and that is readily available in sheets?
RE: Laser cutter transmissive window
TTFN
Chris Krug http://krugtech.com/
