What is HxH reference to Schedule 80 fittings?
Thank in advance!
RE: What is HxH reference to Schedule 80 fittings?
First... come up with a subject for the subject line and a question for the post... just to keep things a bit more professional as you work towards your Journeyman status. Remember, these electronic characters we're typing don't cost much.
It would help a lot if you were to describe the fittings and their application a bit more. I suspect that the HxH is a designation of end connections, but what it may mean isn't occurring to me. For example, you might get a fitting which is SWxTHD which would indicate socket welded on one side and threaded on the other. This type of callout often comes up on extended body valves used for vents and drains or gages. The valve is socket welded into a Sockolet type fitting and typically plugged with a threaded plug or they may have a gage inserted.
So, how are these fittings being attached to the piping?
jt
Interestng handle... my wife grew up near Ione.
So... does H stand for "hub" or something else? The fittings shown in your attachemen seem to be solvent welded like my typical PVC irrigation piping?
jt
These fittings are Hub by Hub (elbow) or Hub by Hub By Hub (Tee)
jte: I was not aware about the existence of a city named Ione, I am from Italy. And yes they are solved welded fittings
Nice to know enough of them got together long enough to make a small village. 8<)
