access to data in iterations
Hi, I am doing a simple plasticity simulation on large deformations using UMAT. The simulation is not converging even for very small time steps.
With URDFIL it is possible to access data for each increment (equilibrium).
Is it possible to access results (displacements for instance) for each iteration in an increment?
So, the data after each iteration in the Newton-process.
Kind regards.
Kind regards.
