non-order harmonics
non-order harmonics
I searched about non-order harmonics but couldnt be able to find anything, if there is such a concept, why do these non-order harmonics occur?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: non-order harmonics
If a frequency is not a multiple of the fundamental frequency it is not a harmonic.
However, a square wave contains components of all frequencies and may induce ringing at a non harmonic frequency.
Bill
"Why not the best?"
Jimmy Carter
I've heard the term "sub-fundamental" harmonics, but that doesn't sit well with the classic definition. Nor are fractional harmonics. If somebody is "finding" these, there is something somebody's missing in the analysis.
old field guy
Such is encountered in vibration analysis. I may have present in my spectrum:
1xTS, 2xTS, 3xTS... (where TS is turning speed)
1*BPFO, 2*BPFO, 3*BPFO...(where BPFO is Ball Pass Frequency Outer race... in generall not an exact multiple of turning speed).
I agree with the others, clarification of the original question is in order (pun intended).
"signal with two fundamental frequencies"
is not stricly correct. I should have said
"signal which includes the sum of two periodic signals that have different fundamental frequencies"
saltukhan needs to characterize the spectrum of of his signal a bit better. 'Non-harmonic' could mean some signal with distinct peaks in the frequency domain or broadband noise. The former are usually generated by some mechanism with a distinct period or resonant frequency, such as your shaft speed and bearing example. The latter are generated by aperiodic mechanisms (corona discharge comes to mind as one example in the T&D biz).
Neil
Interharmonic components are caused primarily by two
sources:
• Variations of the amplitude and/or phase angle of the
fundamental component and/or of the harmonic
components,for example, inverter drives
• Power electronics circuits with switching frequencies
not synchronized to the power frequency, for
example, a.c./d.c. supplies and power factor
correctors
Direct, inverse and homopolar sequences are not sine anymore, they are a sum of distorded harmonic currents.
Maybe this could explain these interhamonics. Perfectly balanced systems do not exist.
