Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...If there has ever been a justification needed for access to the net during working hours, just referring to this site should suffice. Fantastic!..."
Geography
flambter (Aeronautics)
9 Dec 09 7:43
I am trying to print only CBUSH element forces when calling FORCE(SORT1,REAL,BILIN)=200 in the subcase. 200 should refer to a previously appearing SET command.
I am trying to find how to define that SET command. In the quick reference guide, they state that SET is a Set Definition under OUTPUT(PLOT).
Here is what I have tried (first tried with CQUAD elements just to see if it works.)
SUBCASE 1
   TITLE=3G_Up
   SUBTITLE=3G_Up
   OUTPUT(PLOT)
   SET 200 = QUAD4
   SPC = 2
   LOAD = 3
   SPCFORCES(SORT1,REAL)=ALL
It does not seem to work. I get error messages. I have tried many other combinations, but cannot get it to work. Without the OUTPUT(plot) command written in the bdf, the file is working great.
Any idea how it should work?
Thank you!
Spirit (Aeronautics)
11 Dec 09 3:32
Hi flambter,
try to modify your Case Control as follows:
SUBCASE 1
   TITLE=3G_Up
   SUBTITLE=3G_Up
   SET 200 = QUAD4
   SPC = 2
   LOAD = 3
   FORCE(SORT1,PRINT,PLOT,REAL,BILIN)=200
the PRINT command sets the output on the .f06 file, the PLOT to the binary (.op2 or .xdb).
Hope this helps.
Spirit
'Ability is 10% inspiration and 90% perspiration.'
11 Dec 09 13:55
ok, thanks.
It now works, but it doesn't do what I was expectinf. I am trying to output in the F06 files onle the CQUAD4 element forces and not all the CBEAM forces. By modifying the Case Control ,all force output are gone from the f06.
Back To Forum
Close Box
Join Eng-Tips® Today!
Join Us             Close
