Double tubesheet exchangers
Hi all,
Can anybody throw some light on the applications of double tubesheets in shell and tube exchangers?
I specifically want to know about the process conditions which might require the use of double tubesheets.
I would appreciate if some of you could share some reference material on the subject.
Starrpore
Starrpore
RE: Double tubesheet exchangers
Double tubesheet heat exchangers or as well called Double tube technology heat exchangers are usually used when the contamination between the handled fluids has to be avoided. So any eventual leak can be detected using a suitable leackage connection which can cause a signal alarm while the the process plant can continue to operate until the next scheduled maintenance routine.
For additional detaild about, I suggest you to visit the following web site http://www.renzmann.de
Cheers
Patricia Lougheed
Please see FAQ731-376: Eng-Tips.com Forum Policies: Eng-Tips.com Forum Policies for tips on how to make the best use of the Eng-Tips Forums.
Mike
Use of double tubesheet HXs implies that an active leak detection system is also included. There are many types of this system.
Double tubesheet HXs are very difficult to repair...
My opinion only
-MJC
