Macro Help
Macro Help
Macro Help
A fellow over at solidworks community helped me out and wrote a macro for me.  It's works fine on my work machine but I can't get it to run on my home machine.  I asked for some help over there but no responses.  I was hoping someone here could help.
I get a run time error. See attatchment.
My home rig specs are
SW2009 32 SP 1.0
Home built pc
Nvidia Quadro FX 1100
Core 2 1.8GHZ, 2GB RAM
XP Pro 32 SP2.0
work machine specs are below.
here is the code
Dim swApp As SldWorks.SldWorks
Dim swModel As SldWorks.ModelDoc2
Dim swDraw As SldWorks.DrawingDoc
Dim vConfs As Variant
Dim i As Integer
Dim sDrTemplate As String
Dim lDrSize As Long
Dim sOutputFolder As String
Sub main()
    Set swApp = Application.SldWorks
    Set swModel = swApp.ActiveDoc
    sOutputFolder = Left(swModel.GetPathName(), Len(swModel.GetPathName()) - Len(swModel.GetTitle()) - 7)
    sDrTemplate = swApp.GetUserPreferenceStringValue(swUserPreferenceStringValue_e.swDefaultTemplateDrawing)
    lDrSize = swDwgPaperSizes_e.swDwgPaperA0size
    vConfs = swModel.GetConfigurationNames()
    For i = 0 To UBound(vConfs)
        Set swDraw = swApp.NewDocument(sDrTemplate, lDrSize, 0, 0)
        swDraw.Create1stAngleViews2 swModel.GetPathName
        Dim swView As SldWorks.View
        Set swView = swDraw.GetFirstView
        While Not swView Is Nothing
            swView.ReferencedConfiguration = vConfs(i)
            Set swView = swView.GetNextView
        Wend
        Dim swDrawModel As SldWorks.ModelDoc2
        Set swDrawModel = swDraw
        swDrawModel.ForceRebuild3 False
        swDraw.InsertModelAnnotations3 swImportModelItemsSource_e.swImportModelItemsFromEntireModel, 32776, True, True, False, False
        swDrawModel.Extension.SaveAs sOutputFolder + swModel.GetTitle() + "_" + vConfs(i) + ".slddrw", swSaveAsVersion_e.swSaveAsCurrentVersion, swSaveAsOptions_e.swSaveAsOptions_Silent, Nothing, 0, 0
        swApp.CloseDoc swDrawModel.GetTitle()
    Next
End Sub
Certified SolidWorks Associate
SW2009 X64 SP 1.0
Dell Precision T5400
Nvidia Quadro FX 5600
Xeon 2.5GHz Quad Core, 4GB RAM
XP Pro X64 SP2.0
RE: Macro Help
Is your other computer a 64-bit?
RE: Macro Help
no 32
SW2009 X64 SP 1.0
XP Pro X64 SP2.0
RE: Macro Help
Write/Start a new macro on your home machine and copy paste the codes. I'm sure some reference library are missing.
Or
Edit the macro in VB editor. Go to Tools > References and look for missing libraries
Deepak Gupta
SW2009 SP4.1
SW2007 SP5.0
MathCAD 14.0
RE: Macro Help
I unistalled and reinstalled hoping that would help.  Same results.
I have checked the ref library and they are the same.
I did copy it to a new macro on my home machine.
SW2009 X64 SP 1.0
XP Pro X64 SP2.0
RE: Macro Help
But your signature says your system is 64 bit.
Deepak Gupta
SW2009 SP4.1
SW2007 SP5.0
MathCAD 14.0
RE: Macro Help
Work is 64 home is 32.  Both have SW2009 SP1. I tried the copy from work that ran fine and copied the code into a new macro neither worked on my home machine.
The writer of the macro said to check my default drawing template in settings. He thinks it's not getting a drawing template therfore it has a empty drawing.
I will try that when I get home.
SW2009 X64 SP 1.0
XP Pro X64 SP2.0
RE: Macro Help
There are issues with VB6 on 64-bit machines.  Something written on a 32-bit machine may not work on a 64-bit machine, and vice versa. I notified the API development team of this issue in person at SolidWorks HQ in August 2009, and they seemed surprized.
Matt Lorono
CAD Engineer/ECN Analyst
Silicon Valley, CA
Lorono's SolidWorks Resources
Co-moderator of Solidworks Yahoo! Group
and Mechnical.Engineering Yahoo! Group
RE: Macro Help
This one was a user error.  I didn't update my default template so the template it was trying to use was not there.
Works great and is a nice macro.  I'm trying to figure out how to make it populate predefined views of a template.  Once that is ironed out this will be a nice macro for automating simple drawings.
SW2009 X64 SP 1.0
XP Pro X64 SP2.0
