Alternate program recommendations
I am learning ETABS, and I have to say it seems pretty unstable and is fairly frustrating. Does anyone have a recommendation for another program or one that seems more current with an updated interface? I spend a lot of time fixing small issues with the models, redrawing walls or slabs that don't connect.
Advice is appreciated. Thanks. :)
RE: Alternate program recommendations
The thing is, with Etabs, you can already know whats wrong with your model because it gives you some warnings and the coordinates of it
Its just giving the information on overlapping areas, lines etc.
One engineer told me once that software is all about GIGO garbage in garbage out, or if your in Europe you can say it RIRO, Rubbish in rubbish out
i cant see the real distribution of etabs from slab to beam
they said that the load is already transferred to the column, but i need to see it in beam,how can i do that?
please help me
etabs is user friendly and one of the best when it comes to building designs..
