Profile -Chained Dimensions- Stack up
If I have several chained dimensions, each defined with a basic dimension and a profile tolerance. Is the last dimension cumulative (sum of the basic dimensions + the worst case profiles) or can I just add all the basic dimensions in the chain and apply the profile once to the last edge?
Robert
Robert
RE: Profile -Chained Dimensions- Stack up
John-Paul Belanger
http://www.gdtseminars.com
Fundamentally, basic dimensions are non cumulative, since the tolerance isn't on the dimension but on the feature itself.
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
Your profile tolerances are with respect to the datums, not the previous dimensions. Unless you are doing something very weird with your datums, the tolerances are not cumulative.
When measured correctly did it pass inspection?
Dave D.
www.qmsi.ca
"Good to know you got shoes to wear when you find the floor." - Robert Hunter
Thank you for your assistance with this.
