Plain Concrete Manhole Cover
I need to determine the plain concrete strength of an existing 4" thick 24" diameter concrete tank cover in flexure due to a 500 lbs load at the center. Chapter 22 commentary (R22.2.2) indicates that plain concrete should be limited to members that are primarily in a state of compression. However, section 22.5 provides the nominal moment strength of plain concrete. Is it acceptable to use equation 22.5 to determine its strength?
Any suggestions will be appreciated
RE: Plain Concrete Manhole Cover
