Can anhydrous ammonia cause erosion for piping?
Can anhydrous ammonia (vapor or liquid)cause erosion or corrosion for piping elbow and tee made of carbon steel or low alloy steel in refrigeration system?
RE: Can anhydrous ammonia cause erosion for piping?
Is there much water? Check the pH?
Plymouth Tube
S
Corrosion Prevention & Corrosion Control
The most critical issue will be Stress Corrosion Cracking, not a severe metal loss if the design is under the general erosion velocity limitation.
References
- NACE Publication 24061
- MTI MS-6
