Square D motor logic plus
I started up a used 300HP 480V screw compressor and found that my programmable overload relay is bad. It is a square D motor logic plus cat# 9065 SP64. I can't find one anywhere. Does anybody know where I can get this unit? I like this model because no porgramming software is needed. I have a 600:5 Ct ratio on a motor with a FLA of 345A and a service factor of 1.15. Any suggestions on a comparable unit?
RE: Square D motor logic plus
See attached:
http
Rafiq Bulsara
http://www.srengineersct.com
"If I had eight hours to chop down a tree, I'd spend six sharpening my axe." -- Abraham Lincoln
For the best use of Eng-Tips, please click here -> FAQ731-376: Eng-Tips.com Forum Policies
You're the man!! And your right about Sq D tech support. They didn't have much to say.
