Calculating KT for a hole
I am new to this website so forgive me. My question is I am in need of information that describes how to calculate stress concentration in a localized area due tapping an existing hole that has a cyclic life. To expand my question there is a rotating disk that has a certain amount of holes in it. Each one of these will be tapped and a threaded plug will go inside. I am trying to look for information that would tell me how to calculate what the consequences are from tapping the hole. By consequences I mean will I have a localized stress concentration, will the cyclic life of the disk be reduced, may I induce a localized crack that could propagate and reduce my life cycle, calculating Kt factor?
Thanks ahead of time for any information Matthew.
RE: Calculating KT for a hole
We need more information what is this disc, whats its function, what load is it under? can you upload a sketch.
desertfox
What load if any is put on the threaded plugs?
Also what stress levels do you have on the disc during service.
desertfox
If the holes are not in a stressed area then I don't think you have a problem and the only stresses you will generate is from screwing the plugs in.
Stresses can be estimated for threaded joints at this site below and I also give you the link for stress concentrations for holes for reference:-
ht
ht
desertfox
I do have another question though, what should I read to find out information about the way to predict the residual stresses caused at the root of the tapped hole? I am looking to find a difference between fine, coarse, or rolled threads and there impact on tapping the hole?
Look at this site and scroll down to class numbers 28 to 32
http
desertfox
Thank you very much for your thoughts and the information you have shared with me.
I've been looking for a paper I had that had considerable information about holes in disks and fatigue cracking from knife edge holes and rounded edge holes. I haven't found it as yet. Here is one article that may be of assistance.
http://ww
I would look to form the threads if possible instead of cutting same.
htt
NASGRO:
You might be able to find someone who has access to NASGRO to checkout your exact conditions.
http://
Sir did you happen to come across the paper you discussed in your post??
A. F. Grandt, Jr., "Stress Intensity FacTors for Some Thru-Cracked Fastener Holes," International Journal of Fracture, vol. 11, No.2, 1975.
You might do a search using Dr Grandt as keyword as for some reason his name popped up in the windmills of my mind.
http://cobweb.ecn.purdue.edu/~grandt/
I would also do a search on NASA. For some reason my system is getting error messages saying to allow Java Scripts when I Try to look at papers on their website.
