open post processed file with custom editor
Is it possible to set a custom G-code editor as a default application to open post processed files in NX7?
RE: open post processed file with custom editor
# This variable controls which text editor will be used
# when it is invoked from the KF class editor
# EDITOR=notepad.exe
Sandro Anderlini
Mould designer
Macerata - Italy
If you want an editor to start when you finish postprocessing, that can be done at the end of the post. There are samples sround - check the NX post library or nx.cam forum.
I am curious - why do you need to edit the posted output?
Mark Rief
Product Manager
Siemens PLM
Can this be done in Postbuilder? How? I didnt find any settings like this. Should it be coded in TCL?
Maybe with a macro or a journal,
or C++ program, you can launch Cimco edit.
I want to know, it can be usufull to send programs by DNC.
Thanks.
