Pipeline Leak Detection Threshold Values
As per regulatory compliance and safety concerns we need to set alarm setpoints for the maximum flow rate and response time if any leak detection occurs.
I read somewhere: In State of Washington, it is mandatory for all pipeline operators to be able to detect and locate leaks of 8 percent of maximum flow within 15 minutes or less.
Do we have any guideline for threshold imbalance limits from DOT in USA or API as general and for California State in specific.
Thanks in advance
Thanks in advance
RE: Pipeline Leak Detection Threshold Values
http://ww
API 1130 Compliance of CPM's (Computational Pipeline Monitoring) leak detection software.
http://
Are you a regulated pipeline?
API 1130 has been added to CFR Title 49 Part 195 and, as such, is a legal mandate.
and,
h
API 1155 Evaluation Methodology for Software Based Leak Detection Systems
http://
A PPT Presentation by LOOP
http
API Standard 1160
Managing System Integrity for Hazardous Liquid Pipelines
http://www.caldetection.com/api1160.html
http://con
"Pumping accounts for 20% of the world's energy used by electric motors and 25-50% of the total electrical energy usage in certain industrial facilities."-DOE statistic (Note: Make that 99% for pipeline companies) http://virtualpipeline.spaces.live.com/
Thanks a lot for providing this comprehensive list which is really helpful to start with.
dcasto
We have liquid butane service transporting through this 10 mile long line. Line is always packed and is in mild temperature area so relatively fast to get the steady state. I plan to use 5% and 5 minutes detection setpoints as guessing that we will have steady rate by this time and have micromotion installed on both ends to check any imbalance.
Working on the regulations to confirm the numbers.
