Unbalanced Moments
Unbalanced Moments
How do I go about finding the unbalanced moment that is transfer to the column supports from a slab?
RE: Unbalanced Moments
but the unbalanced moment is likely to be in the torsion of the slab.
respects
ijr
Why dont you use the equivalent frame method or simply model the columns and the slab?
Since you have posted your question in this forum, I would suggest you model the slab and the column. ACI splits slabs into column, inner and outer strips, so analyse the column strip using SAP2000
respects
ijr
