Mazak Space Gear G48 Mirror Alignment
Hi guys,
I'm trying to align internal bean on my Space Gear SG-48. This Machine has Fanuc control and Panasonic CO2 resonator. Fanuc resonator is easy to align (internal bean) they have control PC where u can hook up your digital multi-meter and get max power by adjusting the Micro meters on Output mirror and Rear Mirror. The concept of these both resonators seems very similar Panasonic also has Micrometers X,Y on Output mirror and rear mirror. Does anyone know how to hook up multi-meter on a Panasonic C02 laser??? Any suggestion/help would be appreciated.
==> Anyone here with panasonic Resonator Alignment Exp at all?
RE: Mazak Space Gear G48 Mirror Alignment
Regards your question......
Is the Resonator a Type 7 or Type 8 panasonic.
Please be careful when setting up a Panasonic, early version the mirror verniers were connected to the HV!!
You will need a power probe to confirm the o/p power from the resonator, but I can give you the basic setup procedures.
If you are in real difficulties contact Graham Eaton at Mazak Laser UK, ex fanuc CNC and Laser Eng
Good luck.
