Journal (.NET) Remove Parameters Command
Hello, would it be possible to modify the program below in order to remove parameters to any oject (solids, surfaces, curves and points) in the part file ?
Thank you
Sample NXOpen .NET Visual Basic program to remove parameters from all bodies in work part
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Imports NXOpen.UI
Imports NXOpen.Utilities
Module remove_parameters_from_all_bodies_in_work_part
Dim s As Session = Session.GetSession()
Dim ufs As UFSession = UFSession.GetUFSession()
Sub Main()
Dim workPart As Part = s.Parts.Work
Dim myBodies As NXOpen.BodyCollection = workPart.Bodies
Dim bodytag(0) As NXOpen.Tag
Dim a_body As Body
For Each a_body In myBodies
bodytag(0) = a_body.Tag
ufs.Modl.DeleteObjectParms(bodytag)
Next
End Sub
Public Function GetUnloadOption(ByVal dummy As String) As Integer
GetUnloadOption = UFConstants.UF_UNLOAD_IMMEDIATELY
End Function
End Module
Thank you
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Imports NXOpen.UI
Sub Main()
Dim a_body As Body
Next
End Sub
End Function
End Module
Sandro Anderlini
Mould designer
Macerata - Italy
RE: Journal (.NET) Remove Parameters Command
CODE
Imports System
Imports NXOpen
Imports NXOpen.UF
Imports NXOpen.UI
Sub Main()
Dim objectTag(0) As NXOpen.Tag
Dim a_point As Point
Dim a_curve As Curve
Dim a_body As Body
For Each a_point In workPart.Points
objectTag(0) = a_point.Tag
ufs.Modl.DeleteObjectParms(objectTag)
Next
For Each a_curve In workPart.Curves
objectTag(0) = a_curve.Tag
Next
For Each a_body In workPart.Bodies
objectTag(0) = a_body.Tag
Next
End Sub
End Function
End Module
// Petter
