spring between 2 nodes with moment-rotation relationship
hi all,
I am trying to simulate a spring that have a moment rotation relationship between 2 nodes in Abaqus/Explict or force perpendicular to the line between the 2 nodes against the vertical displacement.
Can I use beam elements to simulate this behavior instead?
Can anyone please advice? Thank you.
loo yong
RE: spring between 2 nodes with moment-rotation relationship
To do it you can use on of connector elements (e.g. revolute) with linear elastic behavior.
akaBarten
Hi, thank you. I will try it.
