Capillary tubes and TXV
Hello Everybody,
please I'd like to ask you if somebody could recommend me some useful links where I can find suggested dimensions of capillary for system utilizing a TXV Valve.
There is a lot of literature for single feed systems, but I am not able to find recommended dimensions for bigger systems.
Of course I googled it, but without significant results.
Many thanks
Many thanks
RE: Capillary tubes and TXV
Mr. Coldmaster, apologizes for not correct definitions.
What I am meaning is tubes that connect distributor to coil, and I am trying to select right combination.
System utilizes a TXV valve.
So, I suppose I shall focus on page 10, known required capacity and evaporating temperature.
Please, could you confirm that the page is correct ?
many thanks
