control joint in structural concrete
is there any Rules ot Design guidelines for control joint in concrete water reservoire design. Thickness of walls and slab is 300mm. That is in cold weathre expouser too.
thnaks for your time.
RE: control joint in structural concrete
Mike McCann
MMC Engineering
Motto: KISS
Motivation: Don't ask
thanks
If you mean construction joints, the usual spacing is 30 ft.
thanks for your time. I am not sure why engineer did control joint(thats the term they use on plan)on Base Slab of 16X24 mt, thick 300mm. that can be doable in one day or one pour.
control joint allow any movment in cocnrete. so is it any any voloumn replationship with tem. that governs location of control joint.
i agree with both, but i am tring to understand this issue technically in depth so i can prevent any further damange to public assest.
thanks,
rakesh
To me, unless it is necessary for sound reasons, joint should be avoid/minimized in water retaining structures. If it couldn't be avoid, proper preparation for specific type of joint and good workmanship hold the key.
This topic has been repeatly brought up in this forum, do a search you may find many more useful discussion/hints.
